LabWindows/CVI
How to programmatically eject a removable disk (such as a flash card)
I need to be sure that after copying files to a flash card, the card buffer is actually shuffled to allow for safe removal of the flash card (the usual 'eject' option in Windows Explorer). I understand that there is a DeviceIoControl command. Is there anyone who already developed and tested such code?
(7,475 Views)
SUMMARY
Win32 applications that run on Windows NT can programmatically eject media from drives that have hardware support for media removal. However, they must do so correctly to avoid corrupting the media. This article explains how to eject media correctly on Windows NT.
MORE INFORMATION
Windows NT version 4.0 and later support ejecting media formatted with NTFS and FAT file systems without shutting down the machine. Windows NT 3.51 and earlier support the ejecting FAT formatted media without shutting down. However, Windows NT versions 3.51 and earlier do not support removing media formatted with NTFS while the system is running. On these versions 3.51 and earlier the system must be shut down in order to avoid corrupting data on the media.
When a volume is mounted on Windows NT, there are two categories of read and write operations: 1) data operations performed by applications, and 2) file-system structure related operations performed by Windows NT. The second category is used by Windows NT to maintain the file system itself, such as directory entries of files (for example, file times, sizes, names, etc.).
Win32 applications can use either cached or uncached access to files. Windows NT, on the other hand, caches some write operations to file-system data structures to implement a "lazy-writer" scheme. This allows Windows NT to defer some writes to disk until they are absolutely required. This way, only the latest changes need to be written to disk if the file system data is updated often.
Because Windows NT uses a lazy writer system to update file system data structures on media, the media will be corrupted if the media is ejected while the system is updating this information. To avoid this problem, Win32 applications must take the following steps to correctly eject removable media and prevent possible data corruption:
Call CreateFile with GENERIC_READ|GENERIC_WRITE, FILE_SHARE_READ|FILE_SHARE_WRITE, and OPEN_EXISTING. The lpFileName parameter should be \\.\X: (where X is the real drive letter). All other parameters can be zero.
Lock the volume by issuing the FSCTL_LOCK_VOLUME IOCTL via DeviceIoControl. If any other application or the system is using the volume, this IOCTL fails. Once this function returns successfully, the application is guaranteed that the volume is not used by anything else in the system.
Dismount the volume by issuing the FSCTL_DISMOUNT_VOLUME IOCTL. This causes the file system to remove all knowledge of the volume and to discard any internal information that it keeps regarding the volume.
Make sure the media can be removed by issuing the IOCTL_STORAGE_MEDIA_REMOVAL IOCTL. Set the PreventMediaRemoval member of the PREVENT_MEDIA_REMOVAL structure to FALSE before calling this IOCTL. This stops the device from preventing the removal of the media.
Eject the media with the IOCTL_STORAGE_EJECT_MEDIA IOCTL. If the device doesn't allow automatic ejection, then IOCTL_STORAGE_EJECT_MEDIA can be skipped and the user can be instructed to remove the media.
Close the volume handle obtained in the first step or issue the FSCTL_UNLOCK_VOLUME IOCTL. This allows the drive to be used by other processes.
The following code demonstrates how to accomplish safe ejection using the steps described above:
#include
#include
#include
#include
// Prototypes
BOOL EjectVolume(TCHAR cDriveLetter);
HANDLE OpenVolume(TCHAR cDriveLetter);
BOOL LockVolume(HANDLE hVolume);
BOOL DismountVolume(HANDLE hVolume);
BOOL PreventRemovalOfVolume(HANDLE hVolume, BOOL fPrevent);
BOOL AutoEjectVolume(HANDLE hVolume);
BOOL CloseVolume(HANDLE hVolume);
LPTSTR szVolumeFormat = TEXT("\\\\.\\%c:");
LPTSTR szRootFormat = TEXT("%c:\\");
LPTSTR szErrorFormat = TEXT("Error %d: %s\n");
void ReportError(LPTSTR szMsg)
_tprintf(szErrorFormat, GetLastError(), szMsg);
HANDLE hVolume;
UINT uDriveType;
TCHAR szVolumeName[8];
TCHAR szRootName[5];
DWORD dwAccessFlags;
wsprintf(szRootName, szRootFormat, cDriveLetter);
uDriveType = GetDriveType(szRootName);
switch(uDriveType) {
case DRIVE_REMOVABLE:
dwAccessFlags = GENERIC_READ | GENERIC_WRITE;
break;
case DRIVE_CDROM:
dwAccessFlags = GENERIC_READ;
break;
default:
_tprintf(TEXT("Cannot eject. Drive type is incorrect.\n"));
return INVALID_HANDLE_VALUE;
wsprintf(szVolumeName, szVolumeFormat, cDriveLetter);
hVolume = CreateFile( szVolumeName,
dwAccessFlags,
FILE_SHARE_READ | FILE_SHARE_WRITE,
NULL,
OPEN_EXISTING,
0,
NULL );
if (hVolume == INVALID_HANDLE_VALUE)
ReportError(TEXT("CreateFile"));
return hVolume;
return CloseHandle(hVolume);
#define LOCK_TIMEOUT 10000 // 10 Seconds
#define LOCK_RETRIES 20
DWORD dwBytesReturned;
DWORD dwSleepAmount;
int nTryCount;
dwSleepAmount = LOCK_TIMEOUT / LOCK_RETRIES;
// Do this in a loop until a timeout period has expired
for (nTryCount = 0; nTryCount < LOCK_RETRIES; nTryCount++) {
if (DeviceIoControl(hVolume,
FSCTL_LOCK_VOLUME,
NULL, 0,
NULL, 0,
&dwBytesReturned,
NULL))
return TRUE;
Sleep(dwSleepAmount);
return FALSE;
return DeviceIoControl( hVolume,
FSCTL_DISMOUNT_VOLUME,
NULL, 0,
NULL, 0,
&dwBytesReturned,
NULL);
BOOL PreventRemovalOfVolume(HANDLE hVolume, BOOL fPreventRemoval)
PREVENT_MEDIA_REMOVAL PMRBuffer;
PMRBuffer.PreventMediaRemoval = fPreventRemoval;
IOCTL_STORAGE_MEDIA_REMOVAL,
&PMRBuffer, sizeof(PREVENT_MEDIA_REMOVAL),
NULL, 0,
&dwBytesReturned,
NULL);
IOCTL_STORAGE_EJECT_MEDIA,
NULL, 0,
NULL, 0,
&dwBytesReturned,
NULL);
HANDLE hVolume;
BOOL fRemoveSafely = FALSE;
BOOL fAutoEject = FALSE;
// Open the volume.
hVolume = OpenVolume(cDriveLetter);
return FALSE;
// Lock and dismount the volume.
if (LockVolume(hVolume) && DismountVolume(hVolume)) {
fRemoveSafely = TRUE;
// Set prevent removal to false and eject the volume.
if (PreventRemovalOfVolume(hVolume, FALSE) &&
AutoEjectVolume(hVolume))
fAutoEject = TRUE;
// Close the volume so other processes can use the drive.
if (!CloseVolume(hVolume))
return FALSE;
if (fAutoEject)
printf("Media in Drive %c has been ejected safely.\n",
cDriveLetter);
else {
if (fRemoveSafely)
printf("Media in Drive %c can be safely removed.\n",
cDriveLetter);
return TRUE;
void Usage()
printf("Usage: Eject \n\n");
return ;
void main(int argc, char * argv[])
if (argc != 2) {
Usage();
return ;
if (!EjectVolume(argv[1][0]))
printf("Failure ejecting drive %c.\n", argv[1][0]);
return ;
REFERENCES
For more information on the IOCTLs and functions discussed in this article, please see the Win32 SDK Documentation.
For information about how to eject media on Windows 95, please use the following keywords to search the Microsoft Knowledge Base:
(7,475 Views)
FYI, the above is from the following link
http://support.microsoft.com/kb/165721
(6,960 Views)
