LabWindows/CVI
How to re-engineer exe file
 Hi..I have exe file which is created using pascal.
 It is very old file..i dont have source for it. Now i am working
 to re-engineer that tool to CVI.Is there any way to hack that exe file to
 view the pascal source code...?
Thanx and regards,
venki
(4,561 Views)
Hi Monky,
   referring to this forum:
    http://www.experts-exchange.com/Programming/Programming_Languages/Pascal/Q_10335975.html
   (scroll down the page, you'll see the answers), it seems that your problem is not easy to solve...  Maybe it will be easyer to re-write the application (obviously, if you know what it does!).
   Maybe, you'll be interested in boomeranghttp://boomerang.sourceforge.net/, you'll be able to get C code from your exe file.  I think there's no difference between an .exe that originates from a pascal compiler or a c compiler.
   Let me know if this helps! Bye.
graziano
(4,548 Views)
Short answer: No.
If you dont't hold all rights of the tool, reverse engineering is (under most circumstances) illegal
Message Edited by CVI-User on 02-07-2006 09:50 AM
/* Nothing past this point should fail if the code is working as intended */
(4,548 Views)
but...decompilation is legal.....
Based on...
 Section 50B The copyright(computer programs) regulations
 as well as EC91/250/EEC...
It quite interesting subject.......
(4,521 Views)
If decompilation is illegal or legal, it depends upon the license type you own.  For example, I think it's illegal decompile MS softwares.
Bye!!!!!!!!!!
graziano
(4,512 Views)
And it depends in which country you are in, the software is made in...
(4,480 Views)
You're absolutely right!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
(4,469 Views)
