LabWindows/CVI
How to re-open an OPC-connection with after the server was restartet
Hi all,
my software needs to exchange data via an opc-connection. There are about 8 clients. When i restart the opc-server all clients don't communicate via opc anymore. Each DS_Update takes about 1 second. The communication does not reactivate itself.
My code in pseudo code so far:
Init:
for each socket()
    DS_Open();
Polling the receive-data:
for each socket()
    DS_Update();
    DS_GetDataType();
    DS_GetDataValue();
Termination:
for each socket()
    DS_DiscardObjHandle();
I tried to call DS_DiscardObjHandle() for all sockets and the reopen them again with DS_Open() but all sockets remain in the unconnected state and i don't receive any data anymore.
The code looks a follows:
Init:
for each socket()
    DS_Open(); // for each socket
for each socket()
    DS_Update();
    DS_GetDataType();
    DS_GetDataValue();
ReConnect:
for each socket()
    DS_Open();
Termination:
for each socket()
How can i revive an OPC connection after the Server was restarted without restarting all clients.
Greetings, Urs
(3,200 Views)
Hi Urs,
i guess it is a problem concerning discarding objects.
So first of all, you should use DS_OpenEx() instead of DS_OPEN(). This is recommend by CVI. For the diffrence of these two command please consult the CVI help files.
Here is a small suggestion for a structur of a Data Reader:
1. Open a connection and get a handle to the data source using DS-OpenEx. You must specify whethter to configure the DataSocket object manual or automatic updating.
2. Read the data from the source using DS_GetDataValue. If you configure the DataSocket object for automatic updating, the callback function is called when the data changes on the data source. You then must call DS_GetDataValue t read the data. If you configure the DataSocket object for manual updating, there is no callback function. Instead, you must call DS_Update before reading the data with DS_GetDataValue.
3. Process the data according to your requirements
4. Close the connection and discard the handle using DS_DiscardObjHandle.
So you should use DS_DiscardObjHandle after having received your Data.
I hope this helps
For further investigation, I should know what system you use for your OPC server as well as which version of LabWindows/CVI you use.
Regards
Kilian
(3,172 Views)
