LabWindows/CVI
How to read Nested roots/Child tags in a xml file
HI,
I have below xml file, can any one please suggest how to read multiple roots and nested child tags.
Here "Main" is the root
Child1 and Child2 are subroots.
<?xml version="1.0"?>
 -<Main>
      <r1>104</r1>
      <r2>DK99</r2>
    -<Child1>
     -<Child1_Branch1>
       -<Branch1_row>
             <r1>DATA HW</r1>
             <r2>DATA SW</r2>
             </Branch1_row>
         </Child1_Branch1>
      -<Child1_Branch2>
    -<Branch2_row>
             <r1>DATA HW</r1>
             <r2>DATA SW</r2>
       </Branch2_row>
    </Child1_Branch2>
</Child1 >
    -<Child2>
-<Child2_Branch1>
    - <Branch1_row>
             <r1>DATA HW</r1>
             <r2>DATA SW</r2>
       </Branch1_row>
    </Child2_Branch1>
-<Child2_Branch2>
    -<Branch2_row>
             <r1>DATA HW</r1>
             <r2>DATA SW</r2>
       </Branch2_row>
    </Child2_Branch2>
</Child2>
</Main>
(4,160 Views)
Hello bsnayana,
are you aware of the XML instrument driver shipped with CVI? It permits reading / writing XML files and it could help you in handling your data.
You should have a XMLTree example on your machine that demintrates how to use the instrument to read an XML file and display its informations in a tree control.
(4,156 Views)
Yes, I have but still i am not able to read the child tags inside each nested root (Child1 and Child2).
please suggest the function name which exactly points to the next root reference.
(4,148 Views)
Well, I copied your text into a new .xml file and was able to view its content with XMLTree project, provided I deleted all hyphens preceding '<' start tag characters.
Exploring the code you should be able to see haw it addresses the elements in the file.
(4,140 Views)
Didn't get what exactly XML tree. i am new to this XML reading stuff. can you please share your project file.
(4,134 Views)
XMLTree is a public example which is loaded on your PC while installing CVI. You can locate it under <CVI example folder>\apps\xmltree folder.
Display the Welcome page and click on Explore examples... link, or launch the Example finder and search for XML: you should see listed this example together with <CVI example folder>\toolbox\XMLSample project.
(4,129 Views)
Thanks.
(4,112 Views)
