LabWindows/CVI
How to read a binary file LabWindow
I opened a file and specify the file format as binary using VAL_BINARY. Somehow I can not find a function that can be used to read.
           OpenFile( inputFile, VAL_READ_ONLY, VAL_OPEN_AS_IS , VAL_BINARY );
I tried to use read, it complaints C99 does not support this.
Well, all I want to do is read in a binary file byte by byte.
Thank you.
(3,793 Views)
Accepted by topic author qing22
ReadFile () is the function you need to use: you can pass a unsigned char variable to retrieve the file content and either read the file one byte at a time (highly inefficient) or read it in blocks and scan the output buffer to decode it (better).
These are general rules, there may be different ways to read a binary file, e.g. using a struct variable to automatically decode the file if you already know its structure.
(3,745 Views)
Use the standard ANSI C file input/output functions fopen, fread, and fclose.
http://www.cplusplus.com/reference/cstdio/fopen/
(3,732 Views)
Thank you. ReadFile works for me:
- the LabWindows complaints warning of using unsigned char* , instead of char*
- It seems like have to read byte by byte, instead of read a block.
(3,726 Views)
You're right about the type of the variable, sorry for that.
ReadFile (fileHandle, buffer, nBytes); should permit you to read nBytes out from the file.
(3,720 Views)
