LabWindows/CVI
How to read a network shared variable of type cluster into Labwindows CVi
I need to read a network shared variable (updated in Labview) in LabWindows CVi. The network shared variable is an array of clusters.
How do i do this?
Please help.
Alifiya
(3,725 Views)
Hello Alifiya -
Currently, CVI does not support reading an array of structures from a single network variable.  You will most likely need to break out each array element into it's own network variable, and write them all individually.  To see how to read structs (clusters) in CVI, check out the example 3DSimReader.
Let me know if you have any other questions
NickB
(3,708 Views)
Actually - there is another possible workaround...
In LV (certainly not my expertise...), you could flatten the array of clusters to a byte array, send the byte array , and finally reconstitute the elements in CVI.  I created the following array of clusters, and then flattened it to a byte array:
The code that parses this very specific byte array is attached below (you will of course have to modify it to fit your needs - the memory window in CVI can be a huge help here).  Take a look at it, and feel free to let me know if you have any questions.
NickB
(3,705 Views)
