LabWindows/CVI
How to read/wait for an incoming pulse signal?
I'm looking for guidance on how to read a single TTL pulse of 50 millisecond width. (The pulse indicates a remote instrument is ready for further input.)
My program needs to wait for the pulse to occur and then proceed. If the pulse doesn't arrive in say 5 seconds I want to stop waiting and notify the operator.
Can this be done with a binary/analog input channel or do I need a counter/timer input?
If I read a binary input channel repeatedly from inside a loop then there's a change I'll miss the pulse between reads.
I want to use a binary input because I have one available. To use a counter/timer I'll have to devote another I/O module.
thanks!
(3,519 Views)
You could try looking at DAQmxRegisterSignalEvent () function. Here a small KB item about this command.
You should also have ReadDigChan-ChangeDetectionEvent example installed somewhere in your machine: you can search with the example finder with keyword "change".
(3,514 Views)
Thanks Roberto. Great response as always.
I'm investigating whether the serial line interface (com port) can transmit and receive a single pulse (bit). That could eliminate the need to purchase additional I/O hardware for my application.
I found a CVI function called InstallComCallback(). It's description says it executes a callback when certain events occur on the com port. Could one of those events be a single pulse? I'm investigating how the function works but my knowledge of serial communications is limited.
Does serial communications involve only full characters (8 bits?) at a time or can InstallComCallback() be tricked into executing the callback when a single bit (pulse) is received on the serial receive pin (pin 2?) ?
Does InstallComCallback() requre 8 bits before executing the callback? Or will a single "bit" do the trick?
I may eventually answer these questions through experimentation but at the moment I'm struggling.
thanks!
(3,497 Views)
Serial port is not capable of detecting single bit transmits: serial communications involves a small protocol to encapsulate single bits so that a complete character is received so it won't be a solution in your case.
I never tried it but you may want to investigate the possibility to install a callback on some control signal on the serial line: see the help for event mask in InstallComCallback for a list of available signals. As I told you, I never made tests on this subject so you'll have to experiment yourself and search some documentation to understand those signals and how to manipulate them.
(3,485 Views)
Thanks again Roberto.
I value your opinion even if you have not tried it.
Your suggestion to investigate the RS-232 control pins to detect a pulse instead of using the input data pin is a good idea.
(3,476 Views)
