LabWindows/CVI
How to record the Code39 barcode into wordpad by Labwindow
Sir/Madam
I've a difficulty to record down the Code 39 into my notepad/Wordpad by using the Labwindow/CVI 5.5
I've convert the required part no into Code 39 and show at one of the textbox but when i use the fprintf to record the Code 39,the result will not be the barcode type and unable to scan after printout.
Pls help...
Thank
Ronald
(3,316 Views)
Can you attach your code so that we can further investigate the problem, and what is shown up in text file instead of code39?
(3,290 Views)
