LabWindows/CVI
How to remove MeasAppChm file?
The following message appears while installing the NI driver DVD: (Windows 7 x64)
The "NI LabVIEW 2010 MeasAppChm File" installation has failed with the following error:
A later version of this product already is installed on this computer.
After getting the above message I downloaded and installed the latest NI driver software. The same message appears.
I even tried to remove all NI software from the computer using the Windows Install/Remove application. But when I reinstall the driver software by itself the same message appears.
thanks.
(2,875 Views)
Hi querty999,
I check on my computer and that file is in a different directory then the other NI files. Have you tried searching your computer for the file and then manually deleting it?
Josh Brown
(2,860 Views)
