LabWindows/CVI
How to remove highlighting in the CVI Table
   I have a table in which i will be selecting a row but i dont want to see the row highlighted in the table.
please let me know how to remove the highlighting but still i want the row to be selected.
thank you
(3,075 Views)
Hello Haneef,
Here is some quick code that will prevent most events from putting the table into the Selection State and keep it in the Edit State:
int CVICALLBACK ChangeColor (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_GOT_FOCUS:
SetCtrlAttribute (PANEL, PANEL_TABLE, ATTR_TABLE_RUN_STATE, VAL_EDIT_STATE);
break;
case EVENT_LOST_FOCUS:
SetCtrlAttribute (PANEL, PANEL_TABLE, ATTR_DIMMED, 1);
SetCtrlAttribute (PANEL, PANEL_TABLE, ATTR_DIMMED, 0);
break;
case EVENT_ACTIVE_CELL_CHANGE:
break;
case EVENT_SELECTION_CHANGE:
break;
case EVENT_TABLE_ROW_COL_LABEL_CLICK:
break;
case EVENT_RIGHT_CLICK:
return 1;
break;
case EVENT_KEYPRESS:
break;
return 0;
As you can see, I am swallowing the EVENT_RIGHT_CLICK because it is the only event that will put table in the Selection State. Please let me know if this works.
Jeff L.
(3,056 Views)
