LabWindows/CVI
How to remove label/value in a ring?
Hi All!
I a ring control whose label/value entries depends on the content of another ring. What I do is a switch on the content of the "master" ring and a sequence of InsertListItem on the "slave" ring.
However, I am not able to delete the entries that I have added when I switch to another label/value subset.
So my question is: is there a command to remove/eliminate label/value entries from a ring?
Thank you very much for the help
Francesco
(3,886 Views)
Use DeleteListItem to programmatically delete an item from a ring control (and symmetrically InsertListItem to add an item to it).
(3,884 Views)
Wow it work!!!
great!
Thanks Roberto!!
Francesco
(3,882 Views)
Hi Roberto!
since the number of items is not constant, is there a way to retrieve the total number contained in the control?
Thanks again
Francesco
(3,881 Views)
Ok this one I dicovered it by myself 🙂
numberOfItems = -1
to remove all the entries.
Thanks again
(3,877 Views)
Glad to see you've find it by yourself! Smiley Happy In any case, GetNumListItems ( ) returns the number of items in a ring control.
(3,869 Views)
