LabWindows/CVI
How to remove the extra window when I am executing my program?
When I run my CVI program(mycvi.exe) from CVI 6.0, there's an extra window opened that can be seen on TaskBar representing the running program. How to make the window disappear?
I am using CVI acitveX automation server to control the program(mycvi.exe) running. And I hope my main program(myprg.exe) always in the foreground and get the input focus.
(3,155 Views)
You can use:
SetSystemAttribute (ATTR_TASKBAR_BUTTON_VISIBLE, 0);
to remove it from the taskbar. If windows is popping up, you would have to change your code to not have the windows come up when automating.
Best Regards,
Chris Matthews
(3,155 Views)
Chris Matthews:
That helps.
Thanks a lot.
Echo
(3,155 Views)
