LabWindows/CVI
How to save Famos files from CVI
Does anyone have any experience saving measurement data in Famos format from CVI?
Terry
(3,911 Views)
Hello Terry,
I did some research and I didn't find any instances of using the Famos format in CVI.  The format seems like it is raw data, which means that you would probably need some data plugin to read it.  The only results that my search came up with was using the Famos format with a data plugin in NI DIAdem.   I'm sorry that I couldn't provide more information but I hope this helps.
(3,874 Views)
Hi Brandon,
Thanks for  your time!
Terry
(3,828 Views)
 Hi, Terry,
There is a small product named imc components( based on ActiveX com tech). I have realized importing famos raw data  to Labview ,VB and VBA. Currently, I have some problems with how to import famos data into CVI. I do not know know to manage the memory currently since famos raw data structure is complex. For VB and VBA, i can use one collection to manage it.
Have you solved your problem?
(3,579 Views)
