LabWindows/CVI
How to save a picture(.bmp or .jpg) to database(Access or SQL Server)
The version of CVI I am using is 6.0.
First,How to read a picture as binary data by using CVI?
Then , how to save it to the database(Access or SQL Server)?
Your quick reply is appreciated.
Thanks!
Vicent
(4,180 Views)
With regards to BMP files, you can accomplish the first task of yours by using GetBitmapFromFile () and GetBitmapData () functions: the Bits parameter of the last one is the array of binary data that represents the image.
With regards to JPG files, there is no native support of this type of files;  I have successfully used in the past an instrument developed by Guillaume Dargaud and available on his website to manipulate jpeg files: his Jpg_ReadBitmapFromFile () function returns the same bits array of your image.
(4,178 Views)
Roberto Bozzolo,thanks for your help!
(4,168 Views)
