LabWindows/CVI
How to save data in new columns in Excel
Hi everyone,
I'm a french student, working on Labwindows/CVI during my internship. I have a problem with Excel. Indeed, i found a way to save data from a table in CVI, i copy it to Excel (Data provides from a spectrum analyser R&S). However, if i want to save several data (631 points), in the end, i have only 1 column in Excel with the last measurement.
I would like to save the data in a new column everytime but i don't know how to do. Do I have to create a loop? if its the answer, I don't know quite well how to do this.
If someone can help me,
Matthieu
(2,881 Views)
The Excel Report library may be useful to do this.  Add the file excelreport.fp to your project and use the library functions to create a new Excel application (ExcelRpt_ApplicationNew), workbook (ExcelRpt_WorkbookNew), and worksheet (ExcelRpt_WorksheetNew).  Then you can call ExcelRpt_WriteDataFromTableControl to copy the data from your CVI table to a cell range that you specify.
(2,858 Views)
Thank you for your answer, but i already did that. The problem is that I would like to copy the data several time in differents columns.
I found out a way, I add a column "A" at every loop so my data are saved in the A column, loop, new column and the other data are saved in the new "A" column.
I don't know if i explain well my problem, but if there is a better way to solve it...
(2,850 Views)
