LabWindows/CVI
How to scale the font size that make with the CanvasDrawText()?
Trying some ways but not any effectiveness.
David
(5,119 Views)
I would assume that you first have to generate a suitable metafont using, e.g., CreateMetaFont(). In the latter function you can specify the point size.
(5,117 Views)
Thank you, Wolf.
(5,110 Views)
I'm happy that it works for you now.
...if the problem has been solved, you could kindly mark the answer as the solution, thanks.
(5,107 Views)
