LabWindows/CVI
How to send a char containing double quotes using viWrite?
I am using the VISA library in LabWindowsCVI to control R&S Vector signal generator, using the SCPI commands from R&S manual. However, I am facing a problem now because in one of the commands i want to send contains a file name which is in double quotes.
The command I want to send is:
SOURce1:BB:ARB:MCAR:EDIT:CARR1:FILE "/var/user/64QAM-CVI"
and I am using viWrite command to send this. so what i did is i put \ before the double quotes as i usually do in a char, but it doesnt seem to work, and I dont know why!
here is the command I am sending.
status = viWrite (SMW, "SOURce1:BB:ARB:MCAR:EDIT:CARR1:FILE \"/var/user/64QAM-CVI\"", size, VI_NULL);
Please advice 🙂
BR
Ibrahim Ramadan
(3,074 Views)
S. Eren BALCI
IMESTEK
(3,044 Views)
