LabWindows/CVI
How to set color of left y-axis and right y-axis separately?
I have an XY graph with two dataplots. One plot corresponds to the left y-axis and the other to the right y-axis. The plot corresponding to the right y-axis is blue. I'd like to set the color of the right y-axis labels and tick marks to blue to match the dataplot. Is this possible? So far I have only been able to change the axis name for all axis using:
  SetCtrlAttribute (panelHandle,       graphCtrl,  ATTR_XYNAME_COLOR,  VAL_BLUE);
It would be nice if the color attribute could be set for the Active axis only. Any ideas?
Ryan
(3,130 Views)
The easiest method I can imagine to meet your needs is to use two different graphs: the primary graph on which to plot your curves, with the appropriate colors for the left y-axis labels and the right y-axis set as range but with no labels shown; the second used only to display the right y-axis, placed below the first one and drawn on trasparent colors or with all elements hidden except the axis labels, painted with a color conguent with plot color.
(3,124 Views)
Thanks for the reply. I think I'll just use the legend to indicate the plot.
-Ryan
(3,114 Views)
