LabWindows/CVI
How to specify a 'return or \n' as delimiter for file output?
Default is Tab, OK,
I can put ant 'characters' as delimiter,
but don't know how to put '\n' or 'return'
as delimiter.
Because 2000 points will make a long line and
excel can't read. Many editors can't show it.
Thanks.
(2,797 Views)
what function are you trying to do this with? Is this something of your own design in which case, can you attach it here, or is it simply the ArrayToFile function?, in which case, you need to set the number of elements in a group so that the data is inserted vertically (number of groups = number of elements and set to write groups as rows, or number of groups = 1 and set to write groups as columns).
Hope that helps
S.
// it takes almost no time to rate an answer Smiley Wink
(2,797 Views)
