LabWindows/CVI
How to transfer an arrary in CVI DLL to Teststand Arrary variable
    I have an "Arrary of unsigned char" in CVI DLL and need to be transfered to Teststand GlobalFiles.RxStr (RxStr is an array of number) I know I have a potential choice to use "TS_PropertySetValVariant", but don't know how to do that, because everytime when I try to do this, there comes an error: Found "pointer to unsigned char, expected Variant".
    Arrary of unsigned char:
[31,
44,
5A,
03,
1E]
    Expected GlobalFiles.RxStr: (decimal format)
[49
68
90
03
30]
(4,077 Views)
Jacky,
I may be confused about what you are trying to do, and it has been a while since I have used test stand, but I am going to take a crack at it.  I assume you have a dll with a function that returns a char array that you are trying to get into a test stand number array.  Create a local variable for the step that you can pass into the function.  The exact type you need I have forgotten, it may be string, or it may be an array of characters directly in the step, I cannot remember the options under test stand, but test stand 3.0 could handle almost any data type.
Once the function has returned the data in the char array you can use a post step to copy the data from the char array to the global number array, one number at a time.
A variant type is not going to work for this.  The function in the dll would need to changed to accept a variant type in place of the char array.
(4,050 Views)
I got a solution by refering to the context help for TS_PropertyGetValVariant.
Thanks!
Jacky
Example
LabWindows/CVI
    VARIANT tmpVariant = CA_VariantEmpty();
    double *numArray = NULL;
    unsigned int numElements;
    TS_PropertyGetValVariant(propObj, &errorInfo,
                             "Locals.NumArray", 0, &tmpVariant);
    CA_VariantGet1DArray(&tmpVariant, CAVT_DOUBLE, &numArray,
                         &numElements);
    CA_FreeMemory(numArray);
        CA_VariantClear(&tmpVariant);
(4,048 Views)
Hi Jacky,
There is an example in the Teststand examples folder that should help you with this.
Regards
Ray Farmer
Regards
Ray Farmer
(3,994 Views)
Hi jacky,
The propObj this needs to be the SequenceContext reference. How have you derived this reference?
Regards
Ray Farmer
Regards
Ray Farmer
(3,992 Views)
When you build your DLL, see below, the handle "seqContextCVI" is just what you want
int DLLEXPORT PTP_StepType(CAObjHandle seqContextCVI)
 /* Call this function from the appropriate place in your code */
 // to load and display startup panels.
 short errorOccurred=0;
 long errorCode=0;
 char errorMsg[1024];
Jacky
(3,976 Views)
Ok, so why are you not doing this;
    TS_PropertyGetValVariant(seqContextCVI, &errorInfo,
Regards
Ray Farmer
Regards
Ray Farmer
(3,972 Views)
