LabWindows/CVI
How to use 3rd Party DLL which has WINAPI defined functions.
I'm trying to implement a dll into CVI which comes with its LIB and H file for NT.
A typical function:
BOOL WINPAPI GetExFastStatus (.......)
What do I do with the WINAPI
Windows2000
CVI 6.0
Scott Youngren
Northrop/Grumman Navigation Systems
(4,238 Views)
At windef.h, WINAPI is a #define for __cdecl
Be sure to
#define WIN32_LEAN_AND_MEAN
and
#include
/* Nothing past this point should fail if the code is working as intended */
(4,230 Views)
Should read:
#include windows.h
with the appropriate brackets
(4,227 Views)
I would guess that the .h file for the third party DLL #includes windows.h, but if it doesn't, #include windows.h and/or windef.h before you #include the DLL .h file. Add the .lib file for the third party DLL to your CVI project.
(4,222 Views)
So thanks to all who responded. The 3rd party DLL has been successfully implemented.
And I continue to learn how to make things work.
Scott Youngren
(4,199 Views)
I am having the exact same problem as described here, but for some reason I can't get it to work. The error I get is "Undefined symbol '_Gx1838Initialize@12' referenced in "DC Source.c"". The Gx1838 is the function I am trying to use. I have included the .h file for the dll, the .lib file but it still cannot find it. I also have #include before I include the .h file. Do I need to do something with the .dll?
Thanks for any suggestions!
(4,120 Views)
