LabWindows/CVI
How to use MSXML3.0 in labwindow. Can somebody send sample program!!
I am able to load xml. but not able to get node value please help me
(2,982 Views)
MS XML parser is conform to the DOM defined by the W3.
You can find information here :
http://www.w3.org/DOM/
(2,982 Views)
Just create a ActiveX wrapper around the MS XML 3.0 control by using the
activeX wizard in CVI. Then you can just use it like any instrument
driver. I have some sample code at home which I can post, if you like.
Or if you have CVI 7.0, XML is supported.
vishi
(2,982 Views)
