LabWindows/CVI
How to use Squarewave in Libraries
I've just started using LabWindows/CVI. In the Square Wave - Advanced Analysis Library, can I place a variable into the amplitude ? What are the Phase and the Square Wave in this panel ? Thank you very much.
(3,343 Views)
Yes, of course. It must be a double variable.
@Civilwar wrote:
What are the Phase and the Square Wave in this panel?
SquareWave is the generated array of doubles that contains the squadre wave signal of given frequency, amplitude and duty cycle. It must be have least NumberOfElements elements large.
Phase value (another double passed by reference) it the phase of the last element in the generated array: this is useful in case you need to generate a new wave to be concatenated with the previous one without discontinuity or distortion in the signal: passing this value to SquareWave functions generates a new signal that starts from the right moment in the period.
(3,326 Views)
Oh thanks. Can I ask you one more question ? For ex, I want to use the squarewave to generate 2 analog ouputs.
ang1= 2.5 - degree/36;
ang2= 2.5 + degree/36;
Can I use : SquareWave(128, amp,7.8125e-3, &phase, 50.0, &square); then
ang= 2.5 + amp*degree/36;
I'm still not sure about Phase & Squarewave arguments. I've tried to set the values of phase & square like :
double phase=180.0;
double square=128.0;
When I run, I receive the notice Argument is tool small for &square.
(3,314 Views)
I can do already. Thx
(3,309 Views)
