LabWindows/CVI
How to use a 64-bit Matlab ActiveX in a 32-bit CVI?
I have a CVI 9.0 and 64-bit MatLab R2012a installed on my PC together with 64-bit Windows 7.When I try to use "Create ActiveX Controller" wizard to use the Matlab ActiveX,a message went out says"The Type Library is not intended for use on Win32".Seems like it's because my CVI is 32-bit but my Matlab is 64-bit.So I wonder is there any way for me to use the MatLab ActiveX Controller?
PS.I have been checked on this topic:http://forums.ni.com/t5/LabWindows-CVI/How-to-create-ActiveX-Control-in-LabWindows-CVI-2010/td-p/183...
But it's not workong for me due to different CVI version.
Thank you guys.
(3,978 Views)
     I have a similar issue, were you able to figure out a solution to this? Let me know, thanks!
(2,373 Views)
