LabWindows/CVI
How to use env variables in the 'include paths' project settings?
In VS I can do
$(MySwPath)\Include
where 'MySwPath' is an env var....
How can I do something similiar in LW>?
(3,816 Views)
Hi mikieB,
This KnowlegeBase article talks about what you need:
"Working with Environment Variables in LabWindows/CVI"
http://digital.ni.com/public.nsf/allkb/6BE05EADFCC66623862565F60061C96A?OpenDocument
Basically, you'll need to use the function getenv.
for example, you'd do: getenv(MySwPath).
Let me know if you have any questions.
Kristen
(3,787 Views)
'Hi mikieB,
Kristen
Nope, that is not it....try it..it does not work...
I want to access the enviornment vars from the
options->enviornment->includePaths
Window...
anyone else
(3,784 Views)
Hello mikieB,
I checked with R&D and unfortunately LabWindows/CVI does not support using environment variables when specifying include paths.  If you'd like you can can create a product suggestions and R&D will consider including this in a future version of CVI.  Here is a link to the Product Suggestion Center.
Please let me know if you have any questions.
Kristen
(3,759 Views)
A partial workaround is to use the subst command to map a drive letter to the root of a directory tree you want to access, e.g.:
subst X: "C:\Program Files\National Instruments\CVI85"
(This would have to be done each time the computer is rebooted I think).
You would then be able to use this drive letter in your include paths. Later, if the path changes (e.g. if you are moving to a new CVI release) you can just change the subst command you use. You can use subst multiple times to map different drive letters to different folders.
A similar thing can be done by mapping a network drive to the folder, but that is a bit over the top for local folders.
Martin
Certified CVI Developer
(3,743 Views)
