You can find out more about adding images to the menu bar by referring
to the Using LabWindows/CVI»Developing a Graphical User
Interface»Creating a GUI»Menu Bars»Creating a Menu Bar topic in the
LabWindows/CVI Help.
There is also an example under ..\samples\userint\custctrl\toolbar that
shows menus with images. The example is originally meant to show how to
use the toolbar custom control, but it will show you how to use the
menu items with images. Looks like you have most of the things setup
right. I think the only part you are missing is to check the "Show
Images" check box that shows up by selecting the top most menu item in
the "Edit menu bar" dialog.
I hope this helps.
Bilal Durrani
NI
