LabWindows/CVI
How to use niDCPower_ConfigureSoftwareEdgeMeasureTrigger in PXIe-4154 (each vi session has two active channels)?
I am trying to use this function in my CVI code to configure a PXIe-4154 to make measurement based on software trigger.
I saw this RUN TIME ERROR when I execute the code. Error code -1074118587 ... the requested function is not available when multiple channels ar present in the same session.
But this functions is supported by PXIe-4154.
So how do I go about telling the API that I only need to apply to say channel 0, and get over this problem?
(3,369 Views)
Hello Juswanto,
I see that you are getting help from the AE department directly. We will continue with that method of communication. Thank you for contacting National Instruments.
Product Marketer
(3,350 Views)
