LabWindows/CVI
How to use/open a .fp file created using Labwindow CVI5.5 with CVI5
I have downloaded a instrument driver for Sorensen DLM series power supply. This driver is for CVI 5.5 and above. But i have CVI 5. When I load this driver i get the message "Not a valid function panel file". What is the best way to over come this. Do I have write the driver in CVI 5?
(3,426 Views)
You can't. You can open in in CVI 5.5 and save it as CVI 5.0 format, but you can't open in 5.0 unless someone saves it in the old format.
Best Regards,
Chris Matthews
(3,426 Views)
Can you help with this. Can you save it as CVI 5.0. I have attached the .fp file.
(3,426 Views)
Try this
Bilal Durrani
NI
Bilal Durrani
NI
(3,426 Views)
