LabWindows/CVI
How to use "Ivi_ClearErrorinfo()"
What are the possibilities to handle an error during dataaquisition (-10920 = datalosserror during dataaqu. cause of speed limitation of your system). I want to avoid the popup window with the errormessage. Is it possible with the command Ivi_ClearErrorInfo(), if yes, how can I use this command in my programm or are there other possibilities for errorhandling.
(2,847 Views)
The popup should only occur when you are debugging the application in CVI as part of the built in error checking in CVI, not if you build as a release executable. You can turn off automatic breaking on library errors in debugging by going to Options->Run Options... and unchecking Break on Library Errors. The IVI_ClearErrorInfo function is of no use in this case since it is a IVI function for dealing with IVI functions not DAQ functions.
Best Regards,
Chris Matthews
(2,847 Views)
