LabWindows/CVI
How to zoom in/out function in realtime graph chart?
Historical Trend work ok. but doesn't work zoom in/out(Mouse Action, Keyboard Action) realtime graph chart.
any other solutions?
(5,741 Views)
CVI has three types of graphs: xy graph, strip chart, digital graph. I assume you refer to the strip chart. To my knowledge, even if the documentation is somewhat imprecise, zooming and panning work only for the xy graph, and here only provided that the graph control is set to a mode other than indicator.
(5,731 Views)
Dear Wolfgang
No. Use a XY Graph Chart, Implement realtime chart. any other solution?
(5,723 Views)
Hi gosis,
Please try following: right click on the XY Graph border and select Visible Items>>Graph Palette from the context menu, to enable the Graph Palette which will contain the Zoom In/Out tools.
I hope this helps.
Barna Dobai
(5,666 Views)
Hi dobarni,
your answer seems to relate to LabVIEW...?
(5,662 Views)
dobarni
i want labwindows/CVI example. 🙂
(5,630 Views)
Dear gosis,
 As Wolfgang said, there is no zooming function in Charts in CVI. Zooming feature is only available for Graphs. On the following link you may find an example code that is using a graph, so you can have its features(zoom, cursors...),but it acts as a chart(scrolls like a strip chart):
http://sine.ni.com/devzone/cda/epd/p/id/1141
The problem is, that this was implemented in CVI 6 and does not work in 2009 due to some linking errors, still it's a good starting point that you might check.(First comment out the lines the linking errors correspond to)
Hope it helps!
David Varga
NIH
(5,576 Views)
