LabWindows/CVI
I WANT TO HELP ABOUT "FATAL RUN-TIME ERROR"
When i debug the program,it suggest to Unkown source position,thread id 0x00004510
(2,975 Views)
We did some investigation and saw that the failure is related to some font files located in
c:\Windows\SysWOW64\cvirte\fonts
c:\Windows\System32\cvirte\fonts
Could you try remove these files and see if the crahs still occurs. If not, this would be a workaround if you don't use these fonts.
We keep investigating to see the exact cause
http://digital.ni.com/public.nsf/allkb/282C5D41E2BA04F2862574BA007803B9?OpenDocument
http://forums.ni.com/t5/LabWindows-CVI/fatal-run-time-error-unknown-source-position/m-p/425224?requi...
(2,916 Views)
I already heard this sentence!
If you are on Windows 10 Anniversary edition with cvi 2015 and the error is at program exit,  then there's no need to delete font files: download and install f1 patch instead.
If you are not in that situation then some more detail on when and how the error arises are needed.
Additionally,  try reading the numerous discussions in the forum about GPS,  e.g. this one
(2,910 Views)
