LabWindows/CVI
I am experiencing display problems: tabbing through fields causes fields to move on display, multiple buttons appear, button sizing seems to be incorrect. Is there any known problems with conversion of UIR panel display from version 4.x to version 5.5?
e: I am experiencing display problems: tabbing through fields causes fields to move on display, multiple buttons appear, button sizing seems to be incorrect. Is there any known problems with conversion of UIR panel display from version 4.x to version 5.5?I have never heard of such behavior in a simple migration of a UIR from CVI 4.x to 5.x. Have you reproduced this on another machine that is running CVI 5.5? You may be experiencing some display abnormalities on this particular machine that is non-CVI related. Is this happening during run-time or while you are in the UIR editor?
If you continue to see this behavior on other machines you might want to email your CVI 4.x project to National Instruments tech support at www.ni.com/ask so that we can try to reproduce the behavior here. Please try to include a detailed explanation of what you are experiencing.
Jason F
www.ni.com/ask
(2,984 Views)
