LabWindows/CVI
I am trying to run a delay that i can interrupt
I am writing to read a channel then delay for say 60 seconds then read again. I need to be able to interrupt the delay if a certain thing happens. Is there any other function beside the Delay() function? Can you interrupt the Delay() function? thanks, Dgober
(3,038 Views)
Instead of using Delay() and then trying to interrupt it, why not use a timer with the interval set to 60 seconds. Read your channel in the callback for the timer and let anything else happen between EVENT_TIMER_TICK's.
See the timer.prj sample project that ships with CVI.
(3,038 Views)
i didn't even think of that. Thanks for all your help
(3,038 Views)
