LabWindows/CVI
I came across a problem while using the LabWindows SQL Toolkit
The version of CVI I used is version 2009. When I copy the whole project to the remote desk, when I click the exe. file, it will popup a message that tell the database is unconnected. I have configured the ODBC database, and made a database using SQL server.
the codes are in the following:
I will be very grateful if anyone can help silve the problem.Thank you very much!!!
(7,097 Views)
This is the wrong place for such questions... you should post it here
This forum is meant to suggest new features of CVI
(7,091 Views)
I‘m sorry about that. thank you for your  answer.Smiley Happy
(7,084 Views)
