LabWindows/CVI
I can´t compile the Tucker Davis (TDT) system III *.ocx files with activeX controllers using Labwindows 6.0
I use Labwindows for all my work. Now we need to use the TDT system III with Labwindows, but I can´t compile an object with the ActiveX controllers of CVI. The files from TDT are *.ocx.
(3,337 Views)
are you able to register the ocx controls on your machine correctly? I kept on getting missing module errors, but I did see the compile problems you mentioned. Can you use this control correctly in any other language, like VB?. So before you try to use it in CVI, make sure you can register it correctly on your machine, and I would also recommend trying it in another IDE, just to be sure theres's nothing wrong with the control
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,337 Views)
Dear Bilal
I can see the modules with Microsoft Visual C++, but I don´t use this software, also I´m able to make ActiveX controllers work with Matlab. However all my acquisition software are written with CVI and all my acquisition boards (PCI E-6024 and PC-MIO-6040, and 6503 digital board) are NI products, So I really want to use the TDT with LabWindows.
Paul Délano
(3,337 Views)
