LabWindows/CVI
I can't connect to datasocket server when running the debuggable executable
When i runnig the program from the run menu there's no problem, i launch the server and connect multiple process, but when i create a debuggable executable and running, the program launch the server, but the process can't connect it
(2,872 Views)
Hello Pauldj54,
First, what operating system and version of CVI are you using?
Do you see the same behavior with a release executable?
Also are you able to create a debuggable executable from the shipping examples and connect to the DataSocket server?
The basic datasocket examples are located in ..\National Instruments\CVI71\samples\datasocket\reader
and ...\National Instruments\CVI71\samples\datasocket\writer.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(2,862 Views)
