LabWindows/CVI
I can't load the analysis, VXI, or GPIB libraries.
Why can't I load analysis, VXI, or the GPIB libraries? The files are there but when I try to run my program it can't seem to find them. I am using LabWindows version 1.01. I have tried reinstalling and also switching the location of my files. Currently Measurement Studio is in my program files in my National Instruments folder with LabView and other things, but I have also tried having it other places.
(3,012 Views)
Hello jrios,
First, go to your Project Window >> Options >> Library Options... and see if you can check the boxes beside Analysis, VXI, and GPIB. If they are unchecked and greyed out (unselectable), then they may not be installed. Check the \bin directory for nivxi.lfp, analysis.lfp, and gpib.lfp to make sure the function panel libraries are installed. The nivxi.lib, analysis.lib, and gpib.lib import libraries should also be in this directory. Note that the analysis library is only a part of the Full Development System. If you have further issues, submit further details or consider contacting us at http://www.ni.com/ask.
Jeremiah Cox
(3,012 Views)
