LabWindows/CVI
I can't seem to compile this include....
Here is an include file used with GoldMine. I am having trouble starting on line 125.It generates lots and lots of errors.
struct GMWnv;
typedef GMWnv *HGMNV;
Here they have defined a struct GMWnv that is nothing. Is this a C++ vs a C thing, or is this include file just screwed up? How can I modify this to make it compile under CVI 5.5?
(3,107 Views)
It appears as though this may be a C/C++ related issue. If you comment those two lines out and replace it with:
typedef struct GMWnv *HGMNV;
It doesn't complain anymore. Try this out and see if it helps out your application!
Jeremy L.
Jeremy L.
(3,107 Views)
