LabWindows/CVI
I didn't understand the SCAN function
Hi.
This function should be so easy but still I can't get the result:
unsigned char readBuf[20]={0};
char String[20]={0};
Scan (String, "%s>%16x[b1w2]", readBuf);
String=d21c9000d21c9000;
Why the result is this:
readBuf[0]=d2,readBuf[1]=1c,readBuf[2]=90,readBuf[3]=00,readBuf[4]=00,readBuf[5]=00,readBuf[6]=00,readBuf[7]=00
I expected this result:
readBuf[0]=d2,readBuf[1]=1c,readBuf[2]=90,readBuf[3]=00,readBuf[4]=d2,readBuf[5]=1c,readBuf[6]=90,readBuf[7]=00
Thanks.
(2,897 Views)
If you are looking at readBuf with the String display (with F7 key) you can use the "Display entire buffer" option to disply the complete string after the first 00. The display string assumes you are displaying a string, that is usually terminated on \0 character.
Another way of displaying the entire string is to look at it in the Variables window clicking on the triangle on the left of the variable name: the entire array is exploded and you can check individual elements of it even after the "terminator" caracter.
Roberto
(2,897 Views)
