LabWindows/CVI
I get "The attribute value passed is not valid" when trying to add certain controls to the .uir
I'm getting "The attribute value passed is not valid" error when trying to add certain types of controlls to the .uir and the control will not be added (at least it does not show on the UI)
For example I cannot add any Numeric and Text controlls, but I can add others like Command Button and LED.
I tried adding the controls to another project, and also tried creating a brand new project with similar results.  Any ideas?
I am using LabWindows/CVI 2010 Full Development.
Thank you.
(4,438 Views)
This KnowledgeBase article worked to fix it:
Attribute Value Passed is Not Valid When Launching LabWindows™/CVI
I run CVI 2010 on 64bit Windows 7.
(4,431 Views)
This just started happening to me too.  For others, here is the link to the aforementioned article:
http://digital.ni.com/public.nsf/allkb/DD61DA2841971D7F8625751B00701580
(4,112 Views)
