LabWindows/CVI
I have an "Out of memory" error when I compile or Link my Labwindows CVI 6.0 application. Where is the problem ?
system : Windows NT 4.0. I am using Labwindows CVI 6.0.
(3,107 Views)
The problem occured after I put a '.pcx' image file on a panel. I can compile my project in debug mode but absolutely not in release mode, the error message is always "Out of memory". I have tryed to re-install Labwindows CVI 6.0 but nothing changed, still the same problem. For information, the image size is around 500 Ko. Please, any suggestion would be welcome.
(3,107 Views)
hello
Instead of loading that image at compile time, leave the picture control empty and load it at run-time using the DisplayImageFile().
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,107 Views)
Thanks, that's what I tried and It's working !!
(3,107 Views)
