LabWindows/CVI
I have completed the field point cvi interface except for callbacks.But the compiler sends the 10 error messages stating that the �initializer m
ust be constant� for the same to lines: _tmp=FP_Open (valvetest,&identify_server); AND _tmp=FP_Close (identify_server);What did I do wrong?I Open/Close control the beginning/end of program.,so is the same variable needed? Any help is Appreciated Thanks!Errors in LabWindows/CVI after using field point cvi interface
(2,934 Views)
ust be constant� for the same to lines: _tmp=FP_Open (valvetest,&identify_server); AND _tmp=FP_Close (identify_server);What did I do wrong?I Open/Close control the beginning/end of program.,so is the same variable needed? Any help is Appreciated Thanks!Hello faen9901,
It sounds like the variable "_tmp" is not declared properly (or you may have a syntax error on a neighboring line). Try removing it or replacing it with a properly declared variable (possibly called Status or Error). If you have further troubles, you may contact us at http://www.ni.com/ask >> E-mail NI Engineers.
Jeremiah Cox
(2,934 Views)
