LabWindows/CVI
I have developed a LabWindows CVI 5.5 program and am having trouble installing it on certain Windows 95 machines. I get, "fatal error at script line 653 directory not found."
From this first error message you can say OK and get another error message, "fatal error at script line 477 directory does not exist." and then, "Installation unsuccessful try again later."
(2,763 Views)
Hello. It sounds like this error occurs when you are trying to install a distribution kit from an application you have packaged up. What were your target and create distribution kit settings? Is there anything that sets these 95 machine apart from others that you have found the installation to be successful on? It obviously is trying to locate or write a file to a directory specified by the installer program that does not exist on your system.
Thank you for posting your request to the Developer Zone, the best forum for information.
Daniel McChane
Application Engineer
(2,763 Views)
