LabWindows/CVI
I have installed both Teststand3.1 and Teststand3.0 on my laptop, I want to know which is active. Which API function can I use to get this information under Labwindows.
I have installed both Teststand3.1 and Teststand3.0 on my laptop, I want to know which is active. Which API function can I use to get this information under Labwindows. I know I can use the function "RegReadString" like below, but sometimes, this kind of method is not engough effective, because it just check which versions of Teststand have been installed.
 RegReadString (REGKEY_HKLM,
       "SOFTWARE\\National Instruments\\TestStand\\3.0", "Path",
       NULL, 0, &size);
 if(size!=0)
       TetStandPath, size, &size);
  version=0;
 else
       "SOFTWARE\\National Instruments\\TestStand\\3.1", "Path",
       NULL, 0, &size);
  version=1; //
 if(!size)
 responce = ConfirmPopup ("Warning",
        "NI Test Stand 3.x is not installed \n  Do you want to continue?");
                  // next, I can determine which is installed according to variable "version"
Jacky
(3,514 Views)
Hi Jacky,
You can definitely get the version in CVI using the API.  Assuming that you have a variable refering to your instance of the TestStand Engine, you can use the Engine.VersionString property, which returns the full version as a string.  In CVI, the function to look for is EngineGetVersionString where the ObjectHandle input will be your Engine instance.  Let me know if you have any questions about this method.
(3,501 Views)
In order to use the API of  TS_EngineGetVersionString, I need to build a new engine(TS_NewEngine) in order to have a handle, which results into somewhat low efficiency of application. Is there any other solutions?
Jacky
(3,466 Views)
Jacky,
If you do not want to create a TestStand Engine in order to find the active TestStand version, you can go directly to a registry key.  In the registry, you will find the following registry key:
[HKEY_CLASSES_ROOT\CLSID\{B2794EF6-C0B6-11D0-939C-0020AF68E893}\InprocServer32]
This key contains a string with the path to the TestStand API version that is currently.  For example, if TestStand 3.1 was active, the registry key would contain the following string:
[C:\Program Files\National Instruments\TestStand 3.1\BIN\teapi.dll]
If you parse out the name of the TestStand folder containing the TestStand API you can determine what version is currently active.
This should be a more efficient solution,
Santiago D
(3,430 Views)
Thanks Santiago,
Ray
Message Edited by JoeLabView on 02-28-2006 02:11 PM
(3,395 Views)
