LabWindows/CVI
I have problem programming the "Windows SDK COM" the function " CoInitialize" is ok but "CoCreateInstance" doesn't compiled it return strange error mismatch of parameters types... and I don't what to do.
I want to program a Speech Recognition and Text to Speech application with the Microsoft Speech SDK 5 and it is build on COM technology...
(2,967 Views)
Can you post the function definition in question, and any error codes you are getting. Also, list the libraries you are attaching. Its probably a calling convention type error, but without the above info, its a bit vague. I have a small project that I deveopled with the MS Speach SDK and I'm hoping it will help out.
Chris
(2,967 Views)
