LabWindows/CVI
I have problem programming the "Windows SDK COM" the function " CoInitialize" is ok but "CoCreateInstance" doesn't compiled it return strange error mismatch of parameters types... and I don't what to do
Ok function definition is:
STDAPI CoCreateInstance(
REFCLSID rclsid, //Class identifier (CLSID of the object
LPUNKNOWN pUnkOuter, //Pointer to controlling IUnknown
DWORD dwClsContext, //Context for running executable code
REFIID riid, //Reference to the identifier of the interface
LPVOID * ppv //Address of output variable that receives
// the interface pointer requested in riid
and my compiling errors are:
78, 35 Type error in argument 1 to `CoCreateInstance'; found 'CLSID' expe
cted
'const pointer to const IID'.
78, 70 Type error in argument 4 to `CoCreateInstance'; found 'IID' expected
I did try to change the calling convention but always the same error...
Thank...
(3,071 Views)
It looks like this function is expecting these two arguments to be passed by reference. If you put a & in front of the variable name in the function call it should fix it.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,071 Views)
