LabWindows/CVI
I just installed Imaq and w
hen I compile my Labwindows/CVI 5.5 projects I get the following error: "Error compiling resourses. Make sure your tmp directory is writeable and not full." Are there any suggestions as to what would cause this, it did not happen before Imaq was installed.Resource problem with Labwindows/CVI and Imaq.
(2,952 Views)
hen I compile my Labwindows/CVI 5.5 projects I get the following error: "Error compiling resourses. Make sure your tmp directory is writeable and not full." Are there any suggestions as to what would cause this, it did not happen before Imaq was installed.Did you look to see if the Imaq install modified your tmp directory? CVI first looks for environment variables TMP, then TEMP, then it will use the CVI directory.
To see what TMP and TEMP are, from the DOS Command prompt, enter SET. The list of environment variables will be printed. Check that the directories specified by TMP and TEMP exist.
(2,952 Views)
