LabWindows/CVI
I'm doing t
he following project: the Port A of my card 6025 outputs a count. And the Port B read the result at the output of a circuit to test. The problem is that I can't put the results in a table, I don't know how to do this. What's the better solution to do this?
Thank you for the answer...
Yvo
(3,296 Views)
he following project: the Port A of my card 6025 outputs a count. And the Port B read the result at the output of a circuit to test. The problem is that I can't put the results in a table, I don't know how to do this. What's the better solution to do this?Yvo:
I'm attaching a short project that uses the table control. This example logs measurements to the table along with a time stamp. These entries are added to the table with InsertTableRows() and SetTableCellVal(). I hope this helps you get started.
Good Luck!
Chris Wood
(3,296 Views)
