LabWindows/CVI
I'm running LabWindows/CVI 2013 Version13.0.2 service pak 2, and I am not able to Build Distributions. Is there a problem with this version
Executing Build->Distributions doesn't build the distribution with LabWindows 2013 Version 13.0.2 Service Pak 2. I have the full development license. Is there some issue with this version?
(4,977 Views)
Hi, CRice
There are no known issues where building a distribution fails with LabWindows/CVI 2013 SP2. Can you describe the symptoms of the bad behavior you're experiencing in more detail? Are there any errors that appear? Does this only happen with 32-bit or 64-bit distributions?
Daniel Dorroh
(4,968 Views)
There are no symptoms. When I click on Build->Distributions-> Build "Name", the project builds the release exceutable but no distributions folder is created. Are there other licenses needed to turn on this feature? I have the Full CVI Development license(s)
(4,774 Views)
CRice,
Have you tried following the steps outlined here? Does this create a Volume folder in the specified directory?
Julia P.
(4,737 Views)
