Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I need a code example to set up a couple panels using easy_tab.
hendra@ngms
Active Participant
01-23-2002
04:02 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can someone provide a code example of intializing a CVI with a couple panels into easy_tab.
0
Kudos
Message
1
of 3
(3,057 Views)
Reply
Re: I need a code example to set up a couple panels using easy_tab.
Chris Matthews
Active Participant
01-23-2002
05:45 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can find two easytab examples under the cvi\samples\userint\custctrl\easytab\. These should help you understand the easytab.fp tool.
Best Regards,
Chris Matthews
Kudos
Message
2
of 3
(3,057 Views)
Reply
hendra@ngms
Active Participant
Author
01-24-2002
08:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Got it! Thanks very much.
0
Kudos
Message
3
of 3
(3,057 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
